If the network has opened port UDP 3478 the communication will improve. Please note it should be opened in both points, experts and devices.
For the best possible experience, we recommend opening UDP ports 1025 – 65535.
Low data mode tool. Specially designed to maintain the best video quality in low connectivity environments. Use it if you want to force HD quality or higher,
The Basic call mode will give better performance than the Full call mode. Use Basic call mode when it is a 1-1 call and you do not need to record the call or use the voice translator.
